Yeah, I know but just installing that hose seems much easier.
Would you like to fix the actual problem for the same amount of work?
Huh? I'm sure that situation can be chalked up to one of life's strange coincidences (two unrelated events occur simultaneously)...#3. HOWEVER, just for sh!tz and giggles, try adding a bottle of Lucas fuel injector cleaner to your tank. A friend of mine has a 2006 TJ that started rejecting fuel. He was delaying the real fix and added the Lucas stuff to see if it would help with an unrelated rough idle. All of a sudden his fuel tank problem went into hiding. Worth a shot. Six bucks.
6 bucks. Worth a shot, IMO. It’ll probably freeze up on him again, but maybe he’s on to something? Even if it’s temporary, might be a good idea to keep a bottle in the tool box.
Hey I didn’t think NAPA high mileage 10w-30 was gonna help a rear main seal leak, but it did. That’s another thread here somewhere..
Maybe, maybe not. The problem is the valve sticks, is sticky, or stuck due to the cage shrinking and changing tolerances. If something in the cleaner lubed the cage or lubed it just enough to allow the inrush of fuel to move the valve to a new location like stuck all the way down, boom, "fixed".Huh? I'm sure that situation can be chalked up to one of life's strange coincidences (two unrelated events occur simultaneously)...
Great point I hadn't considered, Mr. Blaine!Maybe, maybe not. The problem is the valve sticks, is sticky, or stuck due to the cage shrinking and changing tolerances. If something in the cleaner lubed the cage or lubed it just enough to allow the inrush of fuel to move the valve to a new location like stuck all the way down, boom, "fixed".
That was not my intention.A fuel additive cannot change the physics of a sealed tank pressure-locking. On the other hand, an oil additive that causes old, dry seals to expand can certainly stop a leak. One makes sense, the other doesn't.
The only solution to this problem is to restore a functional tank venting system. The proven solution for that is to drop the tank and remove the ridges on the plunger to allow it to work again. Other solutions exist, but that one is proven and pretty easy, all things considered.
Nevermind. Humbled by the Wizard again.
I’ll start with a big Charlie Brown sigh….
. . . just for sh!tz and giggles, try adding a bottle of Lucas fuel injector cleaner to your tank. A friend of mine has a 2006 TJ that started rejecting fuel. He was delaying the real fix and added the Lucas stuff to see if it would help with an unrelated rough idle. All of a sudden his fuel tank problem went into hiding. Worth a shot. Six bucks. . . .
I know it wasn't, Mr. Blaine, and I like that you did bring that idea up because I hadn't considered that possibility at all. It's good to have other viewpoints pointed out because none of us is always right!That was not my intention.
Ok. That’s done:
#1. You riled up Mr Blaine. Don’t do that. He will destroy you with sarcastic laser beams. Like the emperor in Star Wars.
#2. The “GM flapper hose thingy fix” is not a fix. Period. End of sentence. End of discussion.
#4. If that doesn’t work, you’ll have to man up and drop the tank, LOL.
Feel free to scroll back to posts 361 and 362. I shared some videos, photos, and info that could be helpful.
That may be the case. All of the ones I've messed with have the same issue, the cage shrunk and locked up the valve. I suspect they may not have taken into account the effect of ALL the various additives possible that make their way into gasoline. I know from working on the Savvy tank skid that a tank that has been sitting empty is a lot different dimensionally than one that has had fuel in it full time. Not to mention that gasoline by itself does strange things to plastics. Leaching something out of the cage to make it shrink wouldn't surprise me one bit. That and the tolerances where the valve sits in the cage are way too tight. They could have increased them tenfold, never had this issue and the function would have been unaffected.One of the theories about the cause of TJ refueling issues is that current environmental standards have reduced lubricity of gasoline enough to cause the fuel tank valve to stick.
