I have a 32RH in a 2001 4.0. I’ve had a recurring gremlin that I just can’t fix. The issue is essentially that it won’t stay in 3rd gear under certain conditions. It will shift into 3rd and coast in 3rd just fine. And it seems to be shifting just fine. But under any sort of throttle, even just a slight tap, it shifts into second and stays there until your foot is completely off the throttle. But it’s not all the time. It’s only if I’ve been going 45mph+ for 30 minutes or more.
I have adjusted and replaced the kickdown cable enough that while the issue might still be related, it’s not the cable or the clip on the throttle body, for sure. I also replaced the return spring on it, but it didn’t change anything, so I switched it back to the original.
There’s some additional information that might be relevant. The transmission leaks. I had it “rebuilt” 2 years ago, but I’m pretty confident that it wasn’t actually rebuilt.
I don’t 100% know this transmission, so I don’t know if I’ve been missing something this whole time. So I’m looking for any and all possible causes and things to check. I know with a lot of these posts, responses are kind of “most likely it’s this issue” and while I want that as well, if you’ve got any one off “oh this unexpected issue that was somewhere you’d never expect was actually causing the issue” I’d love to hear that as well.
I’ll try to respond and update as much as I can, and with each suggestion I’ll test and fix and update. I just want this fixed without going to a mechanic, cause I enjoy fixing it, and I don’t have the money for a mechanic to chase down and then fix the issue.
