Pan for oil dripping?
suicideking
Riverside, CA
My main seal drips a bit. I moved to a new house and looking for something to put under it so I don't get oil on the garage floor. What do you suggest?
I see Amazon sells pans and drip mats.
Once moved, is there a cleaning product recommended to get oil off of concrete in the old garage?
Purple Power cleans oil off concrete. Cardboard soaks it up , but makes a drip look like a puddle. I've been doing this for 5 years.
I've been using cardboard in the old garage. I use the boxes our dog food comes in (good size to slide under the Jeep), so just recycle them after a month or so. Though worry that could be a fire hazard, so was thinking of switching to cleanable metal pans.
go to goodwill or a similar place and get a cookie sheet. Put paper towel on said cookie sheet. Slide said cookie sheet with toweling under the Jeep at the precise location of the drip.
I use Pig Mat myself vs paper towel.
I have a flo-tool drip tray. It has a small raised outer lip. Its fairly large, 36x26 maybe? I currently use it under my daily which has a wicked oil pan leak. The size is nice because I can just toss it on the driveway and I dont have to worry too much about how/where I park, I'll still catch the drips. IIRC it was $10-15 from Orielly's.
I have a large pan like what Mac posted, and I put a piece of cardboard into the pan. I should switch to oil dry, but I still have a lot of cardboard from purchasing 2 TVs last Christmas.
Ended up getting one of these.
Thanks everyone for the info, still need to order cleaning fluid.
As listed above, the Goof Off concrete cleaner works well. I had a 2 gallons of used motor oil burst and flood onto my brand new concrete garage floor. I had to do a couple of applications and let it sit for 24 hours each time. It pulled out all of the oil but did leave a bit of discoloration. It's not as noticeable and just looks like a water stain.
The Goof Off is pretty thick and I found using a putty knife gave good even coverage.
I also tried Oil Eater Overnight Stain Remover. It did remove most of the oil but did not work as well as the Goof Off.
Reactions: suicideking
I accidentally spilled radiator flush on my garage floor...sat for a bit too...cleanest part of the floor. Probably didn't do good things to the concrete...since it's probably a decalcifier.
I have a 28x30x2 plastic pan made for a water heater. I set my oil pan on it when doing fuild changes.
I'm praying that ATF is a concrete preserver. If it is, there are sections of my garage floor that will survive armageddon.
Ordered it.
Note on ordering: Amazon only had a two pack for $34. A single would be $22 from a non Amazon vendor.
Found a single for $11.47 on Home Depot with free shipping.
