2002 TJ 4.0 w/ Automatic
Hi all! New to the forum. Just looking for some opinions before I start spending $$$. Sorry if this is long, but just trying to give the whole story. Here is my situation... While driving the TJ my battery hold down came loose. The batter slid to the side and the positive terminal grounded to the frame. Jeep shut off completely and rolled to the side of the road. At the time, I did not realize what had happened. So I sat on the side of the road waiting for a tow with the batter still grounded. It had zero power in this state. Four ways wouldn't work. Nothing. After about 30 minutes I started poking around and saw the issue with the battery. I moved it the batter back and fixed the hold down. Tried to start it, but nothing. When the tow arrived the driver threw a jump starter on it and it worked. Fired right up and drove it home. I put my battery tender on it to get it charged up and check for faults. No issues and charged fine. Jeep sat for a week before I drove it again. Started up fine and was running fine for about 20 minutes. Then the engine just cut out. Did not lose electrical power, but it stalled. After sitting for a few minutes I was able to get it to start again. Drove maybe a half mile and stalled again. Same thing, sat for a few minutes and was able to get it started and made it home. That is where it stands as of now.
I have read a lot of things and my best guess is I messed up the PCM and need to replace it. I can find my way around working on vehicles, but electrical is definitely my weak spot. Any other thoughts or advice would be greatly appreciated. Thanks!!!
