Hey guys im back. So I finally got the underside buttoned up and when I went to test drives it i learned VERY quickly that the knuckle on the rear drive shaft is loosey goosey. I called a local drive shaft shop and he quoted $600+ to rebuild and $400+ for a new one. I have a Tom Woods sticker under the hood. How do I identify if the axle is a tom woods? Also I will be on a 4" lift this weekend running 33's. Do I need an SYE? It has a 2.5 with a standard trans. Transfer case has a rebuilt tag on it. Rear axle is an 8.8. Thank you.
