Hi everyone,
Took my TJ to the beach over the weekend, and the exit was a steep sand hill that was very cut up with lots of very deep ruts. After this, there temp gauge went to 125 degrees and the the below codes were thrown:
- P0841: Transmission fluid pressure sensor/Switch A circuit range/performance
- P0846: Transmission fluid pressure sensor/Switch B circuit range/performance
I'm now having some lagging in shifting gears, or it's not shifting at all. I've had a look at a few other threads and I think I need to do the below:
- Drop all the transmission fluid, change the filter and gasket
- Check all the wiring along the transmission
- Maybe redo the solenoid? I put a new one in in October last year, but I'm concerned I might have cooked it
Is there anything else I'm missing or that I should do? Just want to make sure I'm on the right track
Cheers,
Faith
Cheers,
Faith
