Back to my 99 TJ 4.0 AX15 all new and upgraded pretty much everything! After lots of recent upgrades it was running perfect but outta the blue at about 2750rpms in 4th gear its getting weird intermitant miss and more so under load with mild incline. Couple times when misfired watched Tach bounce from 3000 to 4000 real fast, while other times it just stumbles. Happened couple times in 3rd but other then that will get a backfire shifting up thru 2nd and 3rd then into 4th but very few times compared to the weird miss. All ready changed everything and was getting check engine light tps high and low. TPS is at about .7 as that's as close to .5 as can go and after clearing codes go cel again.....so, TPS is good and so is EVERYTHING else. My thought is the 26 year old ECM so cheeking if anyone else delt with ECM issues and has anyone come across and unlocked ecm in their journeys. Thanks in advance.
