Update on some smaller items I recently installed.
Since I'll be cutting my hood pretty high I won't be able to use the factory rubber hood latches so I got these, the $40 Amazon specials
These are push button style latches. The top piece sits above the hood and a bottom "nut" sandwiches the hood below, and gets secured with some grub screws.
Yea I got some over spray on the hood when I painted the cage
These are designed to mount with a nut on each side of a tab. To simplify the engine bay instead of welding a new tab somewhere I just drilled through my shock tower gussets. But because these gussets sit so high, the hood latch bolts would be too tall if I were to use a nut on top of the tab so I just welded a nut to the bottom of each gusset. This allows the latch bolt to sit lower. And then I had to get creative with a spring mechanism so that the hood pops up when the button is pressed.
Of course I still retained the safety latch in front of the hood by the grille.
I finally got my rear ARB locker hooked up too. My locker came with the compressor when I bought it. This is the smallest compressor ARB makes and it's only supposed to run the locker, nothing else. I have a co2 tank to air up tires and use air tools.
I knew I didn't want the compressor inside the engine bay for heat reasons. Heat is what kills these compressors so as long as it stays cool it should last a while. I dabbled with the idea of mounting it under the drivers seat but I ended up mounting it in the back, on the driver's side wheel well. This keeps it out of the heat, keeps the air line nice and short, and allows me to hear it when it runs so I'll know if I get a leak somewhere.
For some reason the electrical harness the compressor came with wasn't even the correct one so I changed some wires around and made it work for me. I ran all wires along the driver's side of the tub and through the firewall. On the other side of the firewall I made my own wire harness using the ol' crimp-one-end-in-a-vise-and-chuck-the-other-end-in-a-drill-method, and ran it all to my electrical tray.
The air line passes through the factory grommet that's in the driver's side corner of the tub and runs down the cage, along the inside of the frame, onto the upper link and into the housing, just like my diff breather.
The compressor is turned on by the switch panel, and the locker is enabled by the switch next to it. Tested, locker engages and zero leaks. I'm excited to feel what it's like when it instantly engages compared to the Rubicon lockers I had that seemed to take forever sometimes.
I was pretty excited for this one..
I bought a 15" PRP suede steering wheel when I got back from KOH as a commitment to myself to install it at some point.
I eventually bought the rest of the parts I needed for the install. I got an NRG hub adapter pn: NRG-SRK-171H and an NRG quick release pn: NRG-SRK-200BK which will make it easier to get in and out with the high bolsters on my seats.
Removal of the steering wheel was a piece of cake. Everyone says you need a special steering wheel puller but I just used a cheap harbor freight double jaw puller and it came right out.
Installing the hub adapter and the quick release was straight forward too. I didn't hook up my horn switch when I installed it as I don't need it for my upcoming shakedown run but I'll install it before the Rubicon.
And installed.. this might sound weird but this is one of the things that I think just completes a build. I'll be in contact with it 100% of the time when I'm in this rig so it's more than just another part. It now FEELS like a different jeep than what I had, in a good way. It's like a physical object that represents a milestone to this project I've been working on for 2 years straight. Idk, maybe I'm just weird. The suede feels fantastic too.
So I have a few things left to do before taking it out next month including redoing some steering stuff which I'll talk about soon. Since it'll be down for a few days I wanted to take it out for a spin to see how it drove. The last time I drove it I only took it down the street so I couldn't get a feel for it.
I ended up taking a quick rip just outside of the neighborhood yesterday and got it up to speed and damn it felt great!
Although I went with 5.38 gears it actually picks up pretty well. Its more responsive than I thought it would be.
The steering feels great, even without steering assist. (That's on the next post). It tracks straight, doesn't pull, kinda sorta returns to center after a turn even though I have 6° of castor.
The fans come on after they reach operating temp. The radiator fan actually cools it down so much that it'll turn off cause it falls just below 190°.
The heated seats work great, everything sounds good, exhaust sounds perfect. I was stoked..
and then I got back home. I left it running when I went inside to open the garage, I came out and heard the radiator gurgling and noticed the engine temp gauge was pinned
I noticed both fans were off so it overheated.
I did some troubleshooting and found it was caused by the shitty design of the bus bar I used. There's one stud on the bus bar that disconnected from the bar it was sitting on so my relay panel lost its 12v supply. I already know how I'm going to fix it so it's not a big deal. I just hope I didn't blow the head gasket by getting it so hot. But I'm glad this happened now, not while on a gnarly trail in JV.
