2006 TJ, 4.0L, 6 spd.
When I’m decelerating, to slow to a stop, I press the clutch and engine RPMs increase to 2500-3000. If I slide my toe under the accelerator pedal and lift the RPM decreases to normal.
When letting feet off all pedals and simply stepping on the brake to slow, no RPM issues, when I touch the clutch, the RPMs increase. For under accelerator, lift, RPMs reduce to normal.
Near history:
-Checked carpet around accelerator pedal, lubed the accelerator cable both at the pedal and near the throttle body with white lithium grease.
-New IAC: In the past year, was getting codes for IAC with accompanying RPM fluctuations. I cleaned it twice, in ~6 month intervals, codes ceased/normal, then replaced it with a new Mopar about a month ago. No more issues since.
-New TPS: Yesterday I replaced the TPS, battery disconnected while performing swap. During a short drive, thought it was fixed…nope, starting doing the revving thing again. Lifting the accelerator pedal caused RPMs to return to normal.
I’ve got no codes and the Jeep runs great otherwise. I’m leaning towards replacing the throttle cable next. Any suggestions?
Rich
Near history:
Rich
