Can I temporarily turn my 99 TJ into a 2WD convertible?
Other than a bit of side gear slop, (the bubbles), I see nothing definite. But my first thought was bad carrier bearings. If a bearing grenaded or teeth broke off... that will cause seizure.
You might have bent a tube and the housing is just junk.
Being on a real tight budget and owning a 25 year old Jeep is hard to do. Sorry, had to say it.
Dana 30 take-offs can be had cheap, or even free.
As others said, pull the inners, take apart your u-joints and run the outers only. Drain the diff fluid first, of course. You don't need to pull the front driveshaft, Just don't put in into 4 wheel JIVE. Check the sound. You might have gotten a bad - brand new unit bearing. Chinesium probably. Noise on decel is a clue.
You can piecemeal it by detective work, finding the bad bearings or part(s), but it's not that expensive in the long run to rebuild it all.
It would be best to change all the diff bearings and races, and have it done (A complete diff rebuild) by a pro. Have the pinion crush sleeve done by someone who has a little talent and a big damn torque wrench. Change your R&P ratio to what you want it to eventually be.
If it were me I would replace the whole axle and be done.
Man. Such good, sound wisdom.
Thank you. I will sleep on this. And hopefully decide on a direction tomorrow.
And the outer Unit bearings were Timkins I found four years ago. Hopefully not involved because dang it man you should be able to rule out what you've spent good money to replace, right??
I feel like it is the Pinion bearing..
This mess has gotten the best of me, again, I appreciate all the information you guys provide.
Reactions: OldButStillJeeping
Anyone happen to have the diameter of the flange on the stub shaft? May go to fastener and or tractor supply stores to see about the grade 8 bolts and nuts, and can buy multiple of whatever size washers they have (I may actually have some), but it'd be great to have exact size. If and when I do this I'd like to at least have the parts on hand as I pull the axles, and would prefer this way rather than taking apart the like new U-joints to use the stubs.
@mrblaine When assembled with the 4" nuts and bolts, is it secure enough once done, lock nuts? Lock washers? Torqued to spec to hold those bearings? The large washer (what size), and one large washer or two with one on each side?And can I be confident it's going to hold safely in there without cross lock with cotter pin and such?? Torqued and red lock tite?
This is why you buy Timken bearings. If you don't, when it fails they're going to ask "did you buy a Timken" and if you say no, then all the second guessers will come in and say "you shoulda bought a Timken." On the other hand if you use a Timken, when it fails they're going to ask "did you buy a Timken" and you'll be all "yeah man, I did!" and then they'll shrug their shoulders and say "well, what'r'ya gonna do? They don't build stuff like they used to."
Because the truth is everything breaks.
That is correct sir!🤣
That never isn't tiresome.
It is always easy to tell who doesn't understand how things are made.
I'll make you the same fucking offer I've made others of similar ilk. Detroit Axle makes unit bearings. I have Timken late model machined down at the flange to fit our brake kits. It is expensive and time consuming as well as space intensive so I need a quality product with a low attrition rate.
If you are confident in your assertions that name brands are not important and a quality product that can be counted on to deliver based on expectations, then I'll start selling the Detroit Axle versions.
All you have to do is step up when a customer contacts me about a problem. You handle communication, you handle acquiring and sending them a new machined part, and you reimburse me for the machining costs I've lost.
For the record, we have sold about 500 with a zero defect rate and trust me, my customers cut me zero slack about anything they can construe to be covered under any warranty replacement.
Do we have a deal?
Reactions: SamwiseGamJeep
Do we have a deal?
And again, all good to know, and good stats on the Timkin. Even though when I was starting this restoration five years ago I found out that Timkin had gone internationally sourced, by your testing it confirms they've kept quality control up to speed. Those of us coming in out of the dark of inexperience have to either learn by the experience the hard way, or trust the pros like you @mrblaine , some shot in the dark not knowing that Detroit axle is crap, but For the most part I followed advice here on the forums and have always done the best I could afford on this build. Nothing but Timken and spicer on bearings and U-joints.
I couldn't afford your black magic brakes, but hopefully next time I'll be able to.
Sigh, everything doesn't have to be a federal case. It was just a fun comment, because it's true.
Ok, back to my critical subject, trying to go to Huntsville fastener, called and they do have grade 8 bolts, 1" x 4.5, $6. I just need to know if I you know the size of washer to match flange size, and lock nuts- and or lock washer?
@mrblaine
@mrblaine Thank you again, I'll just get three different diameters of washer plus-minus, if they have them. Again, should I lock washer this? Lock nut this? Lock-tite? All of the above??
And in you opinion would you be confident that I can safely run it set up this way until we can afford the permanent rebuild?
I used a Nyloc. I would also use some red Loctite, 271 or 272.
If the washer on the back is large enough and strong enough to capture the outer half of the unit bearing, then it is working exactly the same as the stub bolt on a 2wd Cherokee beam axle. That also means it can run forever like that since you are duplicating the exact function of the current stub shaft.
  • Love
Thank you sir. I'll do it. If I go this route. Figured if I get $20 worth of bolts and hardware, have it on hand, tear into it and feel like I need to destroy two new U-joints and separate my outer stub for use instead, I'll at least have options.
Just had another thought. Torque it to same spec as axle shaft and bolt?
Not really. But, you can just jump up and down on the end of a breaker bar and it will be fine. Unless you're pretty special, I doubt you'll find an easy way to torque a 1" fine thread bolt up to the required torque value.
  • Wow
Reactions: lBasket
Lol, and Yikes! I'm not really special, getting a little long in the tooth, I am 220 6'4 with a big torque wrench that goes up to 250-300.
But ain't in no way approaching 800 anything!
I guess, obviously over torque of the unit bearing is not only a non issue, but it'll handle however tight I can get it.
I'll get @AndyG to come over, and we can both jump up and down on it together like a couple monkeys! He and I together at least bring it up to 300..😆
1 pound of force 1 foot away from the pivot = 1 ft. lb.
2 pounds of force 1 foot away from the pivot = 2 ft. lbs.
2 pounds of force 2 feet away from the pivot = 4 ft. lbs.
To get 850 ft lbs, you can stand on the end of a bar that is 3.86 feet away from the pivot. 3.86 feet x 220 lbs of force = 849.2 ft lbs
Don't hurt yourself. The hard part will be the back up wrench.
Yes sir. I figure the highest setting on the torque wrench, the nylok nut, threadlocker and maybe a lock washer if there's room?
Will take care of it, don't you?
I'm getting all of it, and two sizes of washers at the fastener supply right now.
