So, my stock 2003 19 gallon gas tank has finally reached the point of no return; both the filler neck nipple and the rollover valve have completely deteriorated, and my temporary plastic epoxy fix didn't hold. So, I got the Motobilt Stretch Underbody Fuel Cell, confirming with their sales team that all I needed to make this tank work with my 2003 was the pigtail adapter, later years filler hose, later years vent hose, and the 2005-2006 fuel pump. I've gotten that far, and yet, I've run into 3 issues. 1. There are 2 rollover valves on the stock tank, but only one on the Motobilt tank. What do I do about the rollover valve connector that connects to the rollover valve and the evap/fuel lines? 2. The 2003 tank is compatible only with the filler neck, the vent hose is smaller in diameter and connects to the top of the filler neck and the evap/fuel lines; the vent hose doesn't connect to the tank as it does on the Motobilt tank. So, I'm not sure how I go about connecting the vent to anything, really. Would I need a whole new filler neck? But at that point, what would I do with the current evap line that's connected to the fuel lines? 3. How is the pigtail wired to the electrical connector on the fuel pump? There is no wiring guidance, but I know I can't mix and match colors and go at it blindly. I'm unsure if I'm explaining everything coherently, so I'll attach pictures. I removed the stock tank on Tuesday, under the impression that this was a straightforward install. Their lack of clear directions makse me believe that Motobilt never tried this on a 2003; unless it is clear and I'm missing it. Any and all help is much appreciated, I've been wracking my brain on this since I pulled the tank, no answer from the company after I've emailed them, and I'm coming up short and running out of waiting time (it's my only vehicle and my daily driver).
