Mini Boat Sides & Poison Spyder Fenders
bexar_bones
San Antonio, TX
Hi everyone, I've got a set of PS 3" fenders installed on my '04 TJ and am considering Genright rockers & corners since Savvy is pretty much not an option any more. I know the mini boat sides require bending back the bottom inch of the tub but I'm curious if any one here is running this or a similar combo and, if so, how did you deal with the front fenders? I'm guessing I'll have to cut the bottom of the fender & flare along the same line and then maybe weld a small plate at the bottom of the fenders for rigidity...any one have any pics of how this was dealt with? Am I better off with the standard Genright rockers - or perhaps another brand?
I had hoped to go with Savvy rockers but I don't see the actual steel bolt-on parts (for rockers or corners) offered on the website and haven't heard back from them yet for availability.
Sorry in advance if already posted elsewhere, didn't see it in my search - and thanks in advance.
Just got a call back from Gerald - seems the steel sliders for the rockers & corners for TJ are expected to become available at the end of May/early June for any one else that may be interested, LJ would be available next week or two. Seems the corner sliders are also getting a design update that has tapered ends that he mentioned looked a lot better. He mentioned the earlier versions were designed to work with the factory flares but most folks move away from that so I'm not sure if they'll be OEM flare compatible on the new versions from what he said. Also checking out Flux Offroad someone else recommended in this forum...good looking products.
Well I have the old Savvy sliders and PS high lines. The aluminum slider backer I had to trim to fit the fender, no clue on the new version
View attachment 608039View attachment 608040View attachment 608041View attachment 608042
All you can do is trim and modify the sliders and fenders to make it all fit together.
Reactions: sunnysideup_lj
