Unswitched Power Source
lBasket
Branch Manager
Florissant, CO
What is a good source for unswitched power behind the dash on a 97? I see some people have wires labeled and already back there for switched and unswitched but I do not. Trying to power a cooler, it will shut itself off if my battery voltage gets too low.
I personally would squirt a wire out above the HVAC box and the heater core/AC lines. 3' of wire gets you straight to the battery. Add an inline fuse and it's just too easy.
Reactions: Ashim and Rygrego
I was hoping to just throw a tap on something already back there for the wiring the 12v socket came with, it has an inline fuse. I am lazy lol
A straightened coat hanger taped to a wire...pull the glove box, maybe two screws for the fuse box. It'll take 30 seconds.
I don't trust any of my factory wiring.
Reactions: Rickyd
How many amps does the cooler pull? My cooler runs off ice.
It says 40-55watts, at 12v DC a random online calculator says that is a bit under 5a.
I can't do an ice cooler again after the meat fiasco. Plus this fridge one wasn't more expensive than a decent ice cooler
Reactions: Apparition
I'm going switched source with a delayed relay, I'd rather lose some food than kill a battery. But I did do one that can run on dc and a battery for when the vehicle is off.
Reactions: lBasket
Delayed relay has a timer on it or something? How long? I'm definitely going to do some expirementing in the driveway with it to make sure it doesn't kill my battery before I use it camping or etc.
I have a poor man's DIY jackery thingy I made for running it off a marine battery when I truck camp too
The one I think I'm going to do is 10 seconds. My thought was I didn't want a "thundering herd" sucking all the juice before I can fire it up.
Oh delay on startup. Yeah that makes sense, I was thinking it stays on after shutdown for a while. Seems like a good idea.
What cooler did you get? If my math is right 5a seems super low and hopefully won't be an issue. But I guess I'll see if I need to change the wiring later.
Ran a Norcold on unswitched power in BFE for 6 days and never had an issue with a SuperStarter AGM. Consequences were high, but the cooler was perfect and never allowed it to get below cranking amps.
@lBasket do you have a probe? Just test each fuse in the panel behind the glovebox and find your winner.
Reactions: lBasket
I do and I could do that, but I wasn't sure what it and isn't ok to tap into I guess. Like I'm pretty sure brake lights work with the key off, but will it dim my brake lights?
Do you have any fuse slots that you’re not using that are hooked up annd are unswitched?
My thought on the brake lights is you rarely use them so if the fuse covers the amps then you are good to go. Try for a couple days and see how things go. 👍🏼
I can’t remember where you are staying, so do you have access to AC power? If so just run an extension cord at night and don’t sweat that aspect.
I know Sri well enough to trust his judgement and copied his. I don't need much space and like the battery option.
Reactions: lBasket
Put the probe negative on the negative battery terminal. Put the probe tip on the fuse where tiny metal sliver is showing and see if you have power without the key on. If it lights up you have unswitched power.
Reactions: lBasket
Yeah I was deciding between the cooler he got and this one... Honestly the biggest deciding factor was that I was worried the tall and skinny form factor would annoy me to dig through.
I use my brake lights a lot when I'm driving what're you talking about 🤣 I suppose the LEDs probably take a tiny amount of amps.
Yeah I am hoping the red desert has external outlets I doubt I will bother removing it and putting it every night if it doesn't.
I will poke around in the fuse box tomorrow with my probe light and see if I can find anything, more confident tapping into something with its tiny amp draw
