Banks turbo map sensor throttle body spacer
Steeprocker
Clayton,NC
Recently picked up a used banks turbo kit for a 2005-2006. Unfortunately, it’s missing a few items.
Looking for this throttle body spacer and map sensor. called Banks and they said that they no longer carry these parts. Anyone have a spare one?
Also Does anyone have a 05-06 manual tj/lj with the banks turbo kit and hptuners that would be willing to send a copy of the tune?
Looks like you have the base mount solved. Awesome!
The sensor is from the Neon SRT-4. Took me a while to figure that out when mine went bad.
I believe I’m running the $26 Standard Motor version
I hope you were also able to snag the intercooler as well.
Reactions: Steeprocker
Yes, it is intercooled. Looking at bank’s installation instructions and reviewing the pieces here in the boxes, only missing few items such as an air filter, a t bolt clamp, the oil drain bung fitting & 45 degree elbow and the bracket that supports the front mount heat exchanger. Pretty easy to source and fabricate. The turbo mounting bracket is a bit rust but the turbo itself looks good with no damage or play. The Diablo handheld unit works. However, it says that there are no open licenses remaining.
Reactions: MikeE024
