I foolishly removed all the protective wrappings from the fridge before the counter top guys came to install the back splashes thinking no way would they hit the fridge. Well one of the guys was quite large and he scraped his big ass which had abrasive quartz dust on it on the door and left scratches. To make matters worse someone tried to wipe it off dry and left swirl scratches. This is a fingerprint resistant finish which is actually a clear coated metal. Everywhere I looked online it looked more and more like it could not be fixed and could only be made less noticeable with Barkeeper's friend. I tried the BK Friend and it made it less noticeable but still there. Once I realized it was a clear coat, I realized that the scratches have to be in the clear coat and not on the metal below and the BK friend was not able to polish the clear coat enough to blend in. A new door is $550.
It was time for automotive paint correction products and procedures. I started with a 5000 grit 3M Trizact pad using it wet and only in the direction of the grain. Since I was polishing a clear coat the direction may not have mattered but I didn't want to chance making more scratches against the grain.
This took out most of it, but there was a noticeable haze, so I then followed with Meguiar's Ultimate Compound (Clear coat safe) applied with a damp micro fiber cloth again working it up and down with the grain, then mopping it off with another damp micro fiber followed by a dry micro fiber. After 5 or so applications I now cannot even locate the spot. After searching around on the net for 2 hours last night I never found anyone that was successful at a complete, 100% repair on these so that's when I made up my mine to try the automotive products, which nobody had mentioned.
So long story short if you have a fingerprint resistant stainless steel appliance understand that is is similar to an automotive clear coat and can be fixed the same way. The stainless steel scratch repair kits will not work because you are not dealing with the steel, you are dealing with the paint.
On the other hand, if you have a true stainless steel surface with no finger print resistant coating the automotive products won't work but the SS repair products will.
@AndyG keep this in mind if you run into this on any of your jobs.
View attachment 604291View attachment 604292View attachment 604296View attachment 604297View attachment 604298View attachment 604299
