This is the second Delphi fuel pump Summit Racing has sent me. All was well with this replacement one for a few days and then it sat for a week and now it won't prime. I verified power and ground are present for the 1.5 seconds upon key on. Fuel gauge works fine.
Before I go through the process of yanking another fuel pump out, is there anything else that could possibly create a situation where the pump won't prime or operate even with power? It fired up fine with a spray of starting fluid. So everything on the ignition side is fine.
Everything seems to indicate the pump but what are the odds of getting two defective units in a row?
edit: The power and ground were present at the pump connector. So if it is a wiring problem, it would have to be in the Delphi pump pigtail.
