TJRick
Have a 99 4.0 is there a diagram that explains how to get ride of vacuum lines I don’t live in a smog state and want them gone 4.0 is fuel injection
Sorry, I was just ribbing you a little, Chief.
The first thing you need to know is that it is illegal to do what you are proposing. The second thing is you aren't going to gain anything even if you did it.
That being said, the only way it is worthwhile to remove the emissions systems and associated vacuum lines is to go all the way and remove it all - including your entire electronic fuel injection system. Ever since the 1990s, these (and all other) engines have been controlled by an engine computer that relies on all of the electronic and vacuum inputs to not only operate the emissions systems, but also to adjust ignition timing and the air/fuel mixture. In other words, everything has to work together. If something malfunctions or goes missing, the engine computer is going to try to compensate for the "problem" and something else is going to suffer. This will only result in loss of power, fuel economy, and it will probably shorten the engine's life. It really isn't a good idea for any vehicle with an electronic fuel injection system. And believe it or not, these engines are about as basic as it comes to also have fuel injection. The newer engines today are twice as bad.
If you wish to go completely analog and install a carburetor, then you are after my own heart. But you can also plan on installing a mechanical fuel pump and replacing your entire ignition system to make it run right. And even that's not a good idea anymore because the quality of aftermarket parts these days is terrible.
I hope you make the right decision.
