So I purchased the CavFab spare tire carrier when I was released in november of last yr and I had it painted to match the jeep. After it was painted I let it sit on a cabinet at work till I had time to install it. Doing that led to some time and cavfab letting people know that the stock tail lights would not work so I got bummed out and did not get around to installing because I needed new tail lights and I have been trying to find a set of maxbilt trail tails with zero luck. Last week I finally purchased a set of metal cloak slim LEDs in hoping that it would work. Over the weekend I finally installed everything and the carrier went on easy enough and theres a slight clearance issue since I have some rear corner gaurds but nothing too bad. For the rear tail lights the only way to make them work was to rotate them 90 degrees and drill a new mounting hole in the base plate not the jeep and I got everything to work. I most likely will switch out the tail lights if I find a set of trail tails. The carrier itself looks great and I drove around a bit and no wierd noises but I will take the jeep to the off road park on sat to see if I get any noises. Overall I like the look of it as it looks close to OEM
