Rear of the Jeep is coming along beautifully. Blaine has spent a LOT of calories in making sure everything I want to carry in the rear has a home. I picture a bunch of this happened.
Here is a high level visual to show what goes in where.
@B00mb00m this post is for you
The fridge is a carefully chosen item like everything else in the vehicle. It's good size for a 1-2 day trip (18L/19Qt size) and it can run off 12V vehicle power, or it's own Lithium batteries or off of 110V house power. There will be a battery in the fridge and I will carry a spare when I go on trips. Same company makes one smaller size and a couple bigger sizes. This one was the best choice for my uses.
Those storage compartments are bigger than you think. Easily holds the a Milwaukee M18 battery, a Miwaukee M18 rover light (which is freaking spectacular) and a spare Li battery for the fridge.
Now .. the logical question to ask is where did all that space come from?
People have discussed and talked about storage bags or compartments/ammo boxes and such to make use of this area in multiple threads, or wish Bestop still made whatever small storage boxes they made that fit in this area. I have also seen people lament about how the flat inner fender wells that CJs and YJs had and how that was better than what we got from the factory in the TJ .. and in those same threads, other folks also mention stuff from companies like Motobilt and such that offer complete replacements for the TJ that are more similar to old jeeps.
Blaine decided to go a different route and blaze his own way. The first bit of genius is to see something of utility in a space that usually goes unused/ignored by most of us. Photo below is from google, but I am talking about this weird depression/funny shape in the rear fender well area. We have all seen this our jeeps covered by carpet over and over and most of us pretty much did not see what Blaine was able to see.
Next .. this bit of magic happened where Blaine made a perfectly profiled end fill piece to match the contour of the fender well.
Next, a hole was cut in a appropriately precise location on the long side .. and a hinged door made that closes with a latch. The door was shaped nicely with rounded corners to match the rounded aesthetics on the entire design. Not many will notice it, but in a nicely thought out design continuity, Blaine designed this door to use the same kind of butterfly latch that the overhead compartment (in-between the speaker pods) uses. A piece of ABS plastic was cut, shaped and put in the compartment to give a flat berth. High density foam is used as needed to reduce rattling and movement. Then the entire design was mirrored to the other side.
I was pretty amazed when I saw and realized what he had done. Never once did it occur to me that negative space (for lack of a better word) could be used this effectively. We all know that Blaine is very skilled in execution and having seen repeats of his beautiful execution of outboards and such, have even come to the point where we take the work for granted .. but what is less understood and appreciated is the vision he has for problem solving and coming up with NEW things like what is being demonstrated in this build.
It's marvelous see him come up such creative solutions in real time, using minimal but excellent use of right materials and fully inside his design envelope of “everything you need and nothing you don’t” and "everything needs to work together as a whole" .. and doing all that when I am unable to give full clarity on what I need/want other than very loose descriptions of how I typically use the Jeep. Watching this from the front row as I have is a real treat. Thank you Blaine for everything you do.
