Not much, but was messing around on the passenger side and found that the bolt holding the seat belt mechanism at the bottom was nearly falling out. Grabbed the T50 and got it safe.
How does that even loosen up
How does that even loosen up![]()
After years of some precarious jenga block balancing to add some extra height to my jack I came across 911 Motorsports 4x4 floor jack extension.
I am very excited for this thing. Anyone have any experience with them?
https://www.911motorsports.net/4x4-Floor-Jack-Extension_p_77.html
I only dream of doing that haha...I'm lucky if I can even SEE what's on the top shelfBeing so tall is a blessing and a curse. I just don't fit in so many things like cars, planes, clothes and doorways, but I can reach the top shelf at the grocery store!
The radio or there should be 2 wires behind the glove box not connected to anything labeled "switched hot" and "battery hot".Woke up this morning with sore fingers and hands , pain in my thighs - forgot there were even muscles in them after last nights adventures, decided to swap out the plastic outer fender extensions with stock ones - much cleaner look. And of course the perfect aftermarket fit which required some finesse and a self tapping screw here and there.
Next up will be some factory switches from Ebay for the lockers going in soon. Any idea where to grab an easy switched hot in the area under the HVAC controls?
Does you rig have the round 12 volt power outlet and cig lighter? If I recall, one of those is switched.
Left side (cigarette lighter) is switched, right side (power port) is constant
Another giant!!
Do you guys just lift your jeeps so they're easier to get into?
Thats good to know!!! I've been distracted with the new drip from the lower radiator hose top clamp. The worst one to get to of course. Seems to be more than finicky. I may try a worm gear clamp in lieu of the constant pressure clamp.
I used the right side to fit a surface mount usb power adapter already.
No to using a worm gear clamp. Leaks will develop over time with temperature changes. Keep the constant tension clamp. If it's shot get a new one.
No, it’s easier to get underneath and work on them.
Correct, no need for a jack and stands for many maintenance / repair jobs.
