Pics of your Jeep with 15” wheels and a 2.5” lift
Here you go...
33x12.5 on a 15x10, 3.75" BS
2.5" SL. No BL.
No rubbing but it's my DD and has never sees terrain that would stuff 'em.
Stuck out way too far with the stock flares and still extends past the BW flatties
Thats weird. My 32" mickeys fit just fine with a little room to spare before touching the bumper.
Your 32" tires may be a bit on the small side.
My 265/75R 16" Goodyear Wrangler tires are just a hair taller than my previous 32" BFG A/T tires. If they were any taller, they would absolutely not fit without a body lift.
Reactions: ChadH
Mannnnnn I wish my jeep was yellow
Funny, yellow was never even a consideration, forest green, kaki
Or patriot blue were the only colors I was interested in, then I found this relatively unmollested towd I kinda tossed the other colors out the window
You shoulda seen the look on Mrs voodooridr's face when we showed up to look at a yellow jeep
Reactions: lBasket
It's such a good color for a jeep! Or any vehicle really... Has it grown on her yet?
What’s with that fender within the fender? I haven’t seen that before.
Ha I should have noted that. It was a deep clean day so fenders and rock guards were off. The Bushwacker fenders are hardwired and I was test fitting OEMs so that’s the BW sitting in there.
Old Man Emu 2.5" springs, no body lift, and 32 x 11.5 tires on 15x7 wheels. 3.73:1 gears.
Plenty of articulation with this setup.
This is almost exactly what I’m planning for my LJ. Not trying to hijack the thread, but what size bump stops did you use? Just looking for a starting point for my build. Thanks
Dunno, I bought the Jeep in 2002 with the lift already installed by the original owner.
Reactions: OkieJoe
