Doing some reading on the gear break-in. I have Yukon gears, here is their page explaining break-in:
https://www.yukongear.com/blogs/the...ide-ensuring-peak-performance-and-longevity_1
According to them, proper gear break-in is extremely important to keep your gears in good condition, and maintain the warranty. I'm not doubting this. But, why does it seem like this isn't necessary for the front axle? I am not finding anyone suggesting, for example, to pull the rear driveshaft and run in 4-Hi and run the same break-in procedure a second time for your front axle. I also don't see any mention of running the break-in procedure in 4wd, and you'd think Yukon is assuming you're doing both axles.
For someone paying a shop I suppose it's different, they aren't going to do one axle at a time. I am, however. I am only one guy after all. Surely that isn't that uncommon for DIYers, I could throw the front axle in and pull the rear driveshaft and do 500mi before pulling the rear axle but that doesn't seem necessary?
Why is this the case? If proper break-in makes your gears stronger, why wouldn't you need/want to do this to the front gearset too? Sure you don't use it on the highway, but strength is important off-road too.
