For those of you that get cold weather (I mean really cold, not just 20°F at the coldest) do you bother using a battery warmer/blanket?
I’m considering picking one up but not sure if it’s really needed. My TJ sits outside and does not get used regularly, it does have a block heater and new AGM battery.
Average temp right now is about -5°F/-15°C, I never start it in colder than -13°F/-25°C even if the block heater is plugged in.
So in temps of lets say 15°F/-10°C to -5°F/-20°C is a battery warmer really needed/that helpful or is just a block heater and good battery enough?
Keep in mind as I said it’s also not driven on the daily, if it was being started every morning could totally see the blanket being worth it.
