Sounds like a timing issue to me
Hmm maybe I’ll check the distributor for a third time then maybe I’m just doing it wrong… im setting the harmonic balancer to the 2nd to last mark on the timing cover that’s notated “0” on the compression stroke (noted by air coming out of spark plug hole), putting a punch through the distributor to hold it in place, rotating the oil pump slit to the 11’o clock position, then sliding the distributor in after taking punch out so it rotates into place and points to cylinder 1’s wire? Maybe I should just replace whole distributor if I’m doing it correctly?
Edit: worth noting that if I leave the punch in when placing distributor into the block it always rests decently past cylinder 1’s wire so this second time I took it out to adjust. Guessing my issue might be spawning there
