If you care to learn a bit, a spring has a job to do within a few parameters for what we need.I’m always surprised when people state spring rates don’t matter.
Fact is if they didn’t matter, the weight of your Jeep wouldn’t matter and neither would your wheel/tire weight and suspension setup. TJ rates on the attached link vary from 130 to 240 and all of those rates will provide a different level of performance. Then you’ve got to factor in your shocks, because if you plan traveling long distances at speed on washboard dirt roads and trails, you’ll soon melt the seals on rancho 5000x.
The bottomline is each owner must first determine what their primary use will be, if it’s highway use, putting around trails and crawling slower areas, then rancho is fine paired with the right springs. If not then you’d be better off investing in springs and properly valved shocks specifically setup for your rig.
https://wranglertjforum.com/attachments/tj-shock-spring-specifications-xlsx.547294/
1- holds the weight at design ride height. Seems obvious.
2- has enough free height to exert a small bit of force at full shock extension so the springs will stay in the mounts.
3- has few enough coils to stay out of coil bind, has enough coils so they don't fatigue and fail prematurely.
Once you get a spring to fit within those rules, then the rate really doesn't matter since the rate for ALL the springs that can do that job will be within a scant few points of each other with regard to rate.
