M
mojowrangler
Guest
My build: '97 Jeep Wrangler Sport, automatic/32RH, 4.1 geared Dana44 front and rear with lockers, 3.5" suspension lift + 1" body lift. I have the original/stock transfer case (not modified or upgraded to the lower geared Rubicon transfer case). I currently have 35" KM3 tires (35X12.50R17) on 17" aftermarket Walker Evans Racing (WER) wheels.
These KM3 tires are in good condition, but don't do well on ice and hard-packed snow, which is a lot of what I will be driving on to get to the trails in Colorado this winter. This vehicle is primarily for trail riding, not an everyday vehicle, but I still want to be safer on the roads in the winter in Colorado.
I bought an extra set of 16" Moab wheels (which were OEM Jeep Wrangler TJ Rubicon wheels) that I plan to put some A/T-3PMSF tires on. I'm leaning toward buying BFG KO3 tires (maybe Falken Wildpeak AT4W, but I like the weight of the KO3s, plus what I've seen in comparison reviews). Now I'm deciding what size tires I should get. I suspect that I will get better overall performance for my build with 33" tires versus 35" tires based on the research I've done so far, and an opportunity I had to drive this Jeep recently with a "temporary" set of 30" tires for testing (see first half of pic below). The power increase with the 30" tires is most noticeable climbing long steep paved roads. Logically, the 33" tires should perform somewhere in between the 30" tires I tested and the 35" tires that I have on it now (see lower half of picture below).
I suspect some folks might tell me it's a matter of preference or the difference will not be that noticeable. That is fine. I'm trying to micro-optimize here! From my perspective there are two advantages to keeping the 35" tires - it arguably looks better and I'll have a small amount of additional clearance. On the other hand, the advantages to the 33" tires should be a small decrease in weight, improved acceleration/stopping, less stress on the drivetrain, and improved gas mileage. I have no idea if these will be noticeable differences that I should care about. I also don't "think" it will look that bad with 33s, versus 35s.
Here's what it looks like with 33s and 35s...
So, the 33s will be somewhere in between. If/when I get the 33" K03s on 16" wheels, I will switch back to the 35" KM3 on 17" wheels when the weather is warm again. I'll probably switch back and forth between the warm/KM3 and colder/KO2 weather tires until the KM3s are worn down or too old to use.
I think this makes the most sense for my situation, but I thought I would post something here in case there's something I'm not thinking about in stepping down from 35" tires to 33" tires on this vehicle. FWIW, the exact size of the 33s I'm looking at are 285/75R16 (32.8"). There's also a 295/75R16 (33.4").
Also, FWIW, I don't have any body clearance issues (no rubbing) with the 35" tires that are on it now and it runs "fine" - it just ran "better" with the 30" tires as expected (for road use). I just suspect that 33" is more "appropriate" for this vehicle than 35" for my use...trail riding with some difficult trails, but I'm not looking for extreme obstacles. It has great clearance with the 35s, and I suspect I won't notice much loss with the 33s, but I'm curious what other think based on my particular build.
