Unsure of my gear ratio
jwtj02
Indy
I picked up an '04 Rubicon with lots of after-market suspension parts. The differential gear tag still says the factory 4.10, but I am guessing it has been re-geared. Currently has 35s on it. I am thinking I could run it in a particular gear at a certain RPM and measure the speed via GPS, and come up with the gearing ratio. Is that flawed logic? Is there a chart or calculator somewhere that I can use? It is a 42RLE btw.
Jack up the rear end, rotate the tire and count how many times the driveshaft rotates for one complete revolution of the tire. If the driveshaft rotates about 4 times, you still have 4.10. If it turns 5 times you either have 5.13 or 5.38.
Reactions: Rickyd
Pics or it never happened. 🤫
With the caveat that both rear tires need to spin at the same rate. Ie,engage the locker first.i like to put tape on fender and tire,pinion and housing as a reference
Checking GPS speed and RPM in a certain gear is a fine way to do it. You can experiment with calculations here. Actual tire sizes are usually smaller than the stated size: for 35s, try 34 to 34.5. http://www.grimmjeeper.com/gears.html
I was hoping to keep the cover on...
You don’t have to take anything off.
You’re watching the driveshaft not the gears.
Jack up the rear end with a floor jack, rotate the tire by hand, and watch the rear driveshaft under the Jeep, count the rotations as you rotate the tire one full rotation.
Edit:
Turn the tire 2 complete rotations if your other tire remains stationary and does not rotate. Turn the tire 1 complete rotation if the other tire turns in the same direction.
(Pulled from How do I determine my axle gear ratio?)
I'd be surprised if it had anything other than 4.10's, otherwise the seller would have mentioned it.
The backstory is tragic, the prior-previous owner died unexpectedly. A friend of his purchased it from the family to help with expenses, and after a couple of years, he said he didn't get the whole jeep-thing... this guy really had zero knowledge about anything with the TJ. The TerraFlex long arm kit is immediately noticeable, and when I asked about it, all he could tell me was that it had a lift kit.
Edit:
Oh, I get it now - thank you for that explanation.
