The last couple times I went offroad everything seems to work fine but after a while (maybe a couple of hours) my pump starts whining and the power doesn't seem to working if at all. This is even on level ground if I'm sitting still it's difficult to turn the wheel. I don't drive my jeep a whole lot around town but I've never noticed a drop in steering performance.
Just went out to the garage to turn the steering wheel while the front is off the ground. I could see a little bit of tiny bubbles after turning the wheel back and forth about 20 times with the engine off. I went back to the front of the jeep and noticed a puddle and it's leaking from the top of the steering box. I've never noticed a leak before and I checked the level and things looked good. Turned the jeep on and turned the wheel back and forth but it doesn't seem to leak.
If I had to guess I would have thought the steering box would be more likely to leak while the jeep was running.
Lots of questions.
1) Do you think the pump is failing? Is there a rebuild kit for steering pumps or should I just go to rockauto and buy a new one?
2) Should I go ahead and rebuild my steering box? Should I try to tap the box? How do you keep metal shavings out of the hole that doesn't drill all the way through (green arrow)?
3) I don't think I'm ready to go hydro assist for 2 reasons. first, I'm not sure I need it. second, the cost is pretty steep if you go PSC. Would adding a cooler help keep the pump happy?
Lots of questions.
