Not specifically because of a body lift. A cable shifter is useful as part of raising the belly skid which very often benefits from a body lift to allow shoving the transmission and transfer case higher up into the body.
The lever arm off the transfer case points different directions depending on if it is a 231 or a 241. Each requires a different cable routing compared to the other.
