Hey all,
Long time lurker to the forum, so first want to thank you all for the incredible wealth of knowledge contributed here — I've been able to learn so much from all of you and have tackled tons of projects I would have never thought were in my wheel-house five + years ago.
So the gist of my current dilemma: I have a 2002 4.0 I6 with just under 150K on it. A couple weeks ago I pulled the valve cover to replace the leaking gasket and install a set of brand new engine tech rocker arms, bridges, and pivots, along with new mopar push rods with the intent of eliminating some top end noise. All went well, and parts all looked great on arrival, however as soon as I fired it up I noticed a new sound. Initially I thought maybe I was now just able to hear something else since the other noise was gone, but decided I should investigate the valve train again incase I misaligned anything. When I pulled the valve cover today, I notice that some of the rocker arms have a slight wiggle left to to right the produces a subtle clicking as the arm contacts the side of the pivot. I thought that was weird, so I checked all the capscrews for proper torque and indeed they're all torqued to 21 ft/lbs per FSM. I'm thinking this must be the source of the sound, as the frequency it would occur at with the engine running seems to line up, additionally the rockers have no vertical give, which leads me to believe there are no bad lifters contributing to the noise.
Does anyone have experience with bad parts from engine tech? The Mopar push rods were in excellent condition and checked true prior to installation so I don't think they are the problem. Or does anyone know if it makes any difference that I did not originally torque each bridge at its piston's TDC? My understanding from the FSM was that was not necessary, just torque once and go... All the rockers look to be lined up perfectly with their valve springs with the correct bridge screw torque specs. I'll see if I can get a couple quick videos uploaded to show my suspicion for the source of the noise and the associated rocker movement along with another video of the sound with everything put back together.
Thanks in advance
Thanks in advance
