Alright fellas, time for more updates!
So we officially planned another Rubicon trip for July to make up for missing this year's trip due to the ol' girl not being finished. I set timeline goals for each item that needs to be done to be able to make this trip happen. Of course that also means getting it done asap to work out any kinks before we hit the Rubi.
To follow up with my electrical portion I needed to add switches in the dash to control everything. I wanted my switches to be in a location I can reach while I'm harnessed in which doesn't leave me with many options. While my harness is tight, I can really only reach the radio, so when I'm on the road everything else is hard to access. When I listen to tunes I don't listen to the actual radio, I just use my phone via bluetooth anyway, so I decided to ditch the head unit altogether. I bought this double din dash panel hoping it would give me more room to mount my switches and whatever else where the head unit normally sits. After it came in I realized it wasn't going to work very well. The double din opening is taller which is nice but it's also way narrower. I ended up just ditching the idea and gave the panel to my dad so he can actually install a double din unit in his jeep.
Back to the drawing board..
Overall, the only switches I need are two rocker switches: one to control my radiator fan and one to control my trans/steering fan, everything else will be controlled by my 6 gang Auxbeam switch panel. So I designed this simple switch mount that fits into my existing head unit housing and had it 3d printed by my neighbor. His printer plate had the perfect texture to match the factory bezel too. I added an extra rocker switch slot into the design which will mount a bluetooth controller to power my speakers for music. It was the first print and it fit perfectly. I can now easily reach everything important while I'm strapped in on the road. I also ripped out the lower section of the dash panel that had the factory switches/accessories I'll never use. When I get some time I'll design another mount for phone chargers/voltmeter and whatever else for that section.
way too many pictures incoming...
And onto what I have been super excited to announce!
I got my.. "creation" completely welded up and put together.
I used a piece of lexan as a view port.
And here she is installed.
And for the big reveal, if no one guessed what it is, it's a... completely over the top, way too expensive windshield washer fluid reservoir
It actually has another purpose too. The radiator throws so much heat directly onto the electrical hardware that it was worrying me a little. This resy now acts as a giant heat-sink and protects the entire electrical tray.
Here it is after I plumbed it all and added some washer fluid. It holds exactly 1 gallon of fluid.
I also added a small white LED on top that shines down into it, because why not.
It's hard to tell on here but I cleaned up all of the factory wiring on the grill. It was a giant mess before. I removed everything I'm not longer using and now nothing's in the way.
So if you guys remember I said I was going to tackle this small coolant leak at some point. One of my welds had a tiny pinhole in it causing a tiny drip when it built pressure. I promised to be transparent with my mistakes on this forum so here it goes. The last thing I wanted to do was completely remove the radiator, drain it, flush it and plug the hole so I said eff it and tried to weld it as is. Huge mistake! As I was developing my weld puddle I dipped the tungsten, panicked, pulled back hard which somehow led to my hot tungsten kissing the radiator just above my weld and pierced a small hole completely through it. Hot coolant sprayed out and covered everything including my gas lens. After a huge cleanup job I removed some coolant from the radiator so it sat below my new hole. Welding this new hole was a NIGHTMARE. If you're unaware, in TIG welding, your material needs to be insanely clean. And here I was trying to plug a hole with literal antifreeze mixing into my weld. I saved you all an absolute horror of a picture of what that looked like. I don't think I've seen that shade of blue that was on my weld. Once it was plugged up with enough filler rod I was able to burn some of it back to get it clean on the outside layer. I used a file to knock it down a bit. And for my transparency, here's a pic of how it ended up.. and of course it's one of the first things people will see when the hood is opened.
Moving along.
The front end, for the most part is done! There's a few small things here and there to do, and fab up some fenders but the rear is what really needs to be done.
I turned the jeep around in the garage, got it to where it's going to be for the next few months and...
