On-board air tank location
DETOUR
British Columbia / CANADA
Howdy All
•Where do you folks mount the air tank for your onboard air ?
•ours is mounted lengthwise D/S behind the TC
• I’m surprised I haven’t sheared off any fittings yet
•being an LJ model, we’ve got a bit more space over the TJ
You'll find most members unless it's required for some other reason don't run a tank for their OBA system since that small of a tank doesn't really accomplish anything when filling tires.
I need one for my AiRock system so I mounted mine behind the drivers seat since I have a 4 link in the rear and had to move my tank. Before I'd gone 4 link I had mine mount in about the same spot as you do.
I plan on putting mine where the factory airbox would be. And a tank is necessary if you want onboard air tools and/or for seating a tire bead, and for scaring the crap out of people with an airhorn.
  • Dislike
Reactions: Tob and jjvw
We’re thinking alike Rubiconned
•My airhorn came off a semi and used to sit crossways across the engine, it’s fun to watch people looking around and there’s no semi in sight 🙈🤣there’s that boy in every man
🚧DETOUR👋🏾
... And a tank is necessary if you want onboard air tools and/or for seating a tire bead, and ...
Neither of these is correct.
As soon as the pump starts when the tank is immediately depressurized, the tank is not doing anything of value.
And I have personally reseated a tire bead with a tiny cigarette lighter powered air pump. I did it to find out and prove the point that a tank is not needed to reseat a tire.
Reactions: MikekiM and sab
Starting fluid
Reactions: hear and DETOUR
Mine is mounted in the same location as the OP's, but without any hang down fittings. And I completely disagree that a tank isn't helpful. I've found that it helps quite a bit. Yes, once its empty, you'll only fill at the rate the compressor can put out, but the compressor is filling the tank the instant you turn it on - AND - when moving from tire to tire. I filled up 8 tires on 2 jeeps from 15 to 30, and the tank only ran dry once.
Of course, it matters what pressures you're pumping from/to, the size of tires, the particular compressor, the size of tank, and your particular airing up procedure. But for myself, I wouldn't have a compressor without a tank, in fact, I'm going to add another small one to the system, although finding a location for it is a bit of a challenge.
Reactions: DETOUR
The only one you got right was the short blast on an air horn. You can easily reseat a tire bead with a bicycle tire pump. Most air tools that one would find useful on the trail have CFM requirements that will outrun even a large tank in seconds putting it purely operating on compressor output.
