School me on solar
Will that system work when the grid is down?
He'll have to answer that, but I think it really comes down to how it's wired. I have a buddy who is a lineman, and he was telling me that illegal solar systems are becoming a concern. The way he put it is, "in a dead line situation you can hear a generator running and know to check for back feeding, but solar panels are a silent killer".
Im nearly certain that it will. As per my other response to you it has a disconnect that automatically isolates the array from the grid when there is an outage.
Edit - I've been doing some reading and it looks like you are correct for residential scale PV systems. You may even be correct for large commercial systems like the one I described. I still work for the same company and will see if my recollection about it operating during an outage and without batteries is wrong.
I have had solar on my roof for 12 years. Here are some considerations:
  • Since California has gone to time of use energy rates, The highest rates hit at 4pm when the sun is going down and solar stops producing. When I had an old fashioned mechanical meter that predated time of use, my bill was considerably less. Electricity in Ca has become another avenue to tax.
  • Most solar contractors are the bottom of the food chain electricians. Don't sign anything until you have a chance to quietly go over the numbers. The solar contractor should also be a licensed roofer.
  • You need South facing roof slope without shadows.
  • Before you put solar on the roof, make sure it is inspected and in good shape as you will have to pull them off for re-roofing.
  • I would consider a solar structure as a patio cover or a car shade if space exists. It takes away the roof leakage issue.
  • Many would disagree with me but I won't put lithium battery energy storage in my garage or on the side or my home. Thermal runaway is a real, they burn at 4000f, spew deadly toxic fumes, and can't be extinguished until they run out of fuel. I am considering adding a windmill and possibly battery storage but it will be lead acid or ni-cad.
  • Consider how many days of full sunshine you have in San Ramon. Your best production times(assuming you aren't in the fog) will be late spring when temps are lower and days are longer.
  • You can always go back and add more but can't return what you have bought. Most sales folks will oversell the amount of watts you need on the roof.
  • Solar panels degrade over time(from memory about 2% per year). Just purchased another 1600watts to make up for the losses after 12 years.
  • Rates in Az are low enough that Solar payback takes too long plus I don't get full sun on my roof.
Hope this helps, Good luck
You
I think you are correct as according to the CA State License Board there are more complaints about Solar Contractors than any other trade buy a far margin.
And now
SunPower
the solar power giant originally based out of San Jose, has filed for Chapter 11 bankruptcy. SAN JOSE, Calif. (KGO) — SunPower, the solar power giant originally based out of San Jose, has filed for Chapter 11 bankruptcy. This comes just over a month after laying off more than 350 of its California employees.
I have a small building that I wanted to keep cool so I bought 4 panels off Amazon for a total of $650. I bought a solar a/c that can switch automatically between solar and grid power for $405. The shed stays cool without consuming any electricity as it is not even hooked to the power in the shed. When the sun is bright enough the ac turns on. So far, this setup is doing what I set out to accomplish.
I will not say it is fail proof as I am not in it everyday but it is certainly limited unless it is hooked to the grid system.
I would not even consider solar for my home because I do not want that ugly ass shit ruining the looks of my home.
Reactions: srimes
Can you link the AC unit?
Reactions: srimes and Zorba
Sweet. How long have you had it?
I see 2 models, with the cheaper one $1445, and the "quick n easy" for $1,900. My ancient heat pump can't keep up in the heat of summer so I'd drop $3k right now for this. Just have to confirm that the panels will fit on my wood shed as I don't want them on the house roof.
Wow...they went up in price. I bought it last October'ish but did not get it installed until right before Thanksgiving. At this point in time I can say that even with the price increase, I would do it again if I had too. Doing well in an uninsulated small building in the direct FL sun.
The mini splits are dirt cheap if the panels don't fit. They even have a mini split with 2 inside units. But these don't have the built in solar switch.
Reactions: srimes
I talked with someone with a new solar system on their house today that sounds like a scam, but I have limited details, so I thought I'd see if any of you had heard of a similar situation.
The homeowner signed a financing contract for a roof mounted solar system, $47,000 on a 1,000 sf house. In the agreement the company was to install the solar system and a "free" HVAC unit, which has happened, then the solar installer was to activate the system and assume the utility bill for a specified time, which has not happened. The homeowner said the panels have been mounted and done for over a year now, but the company has gone silent. Also, her utility bill has gone up. :LOL: Is the scam to sell equipment, then run or close up shop?
  • Wow
Reactions: Apparition
My guess is that these companies get some money from the homeowner and then get subsidies under another company name and when the heat turns up they close the doors of the business that did the selling.
47k on that size house is nothing but fraud.
It's within the standard range around here. The absolute cheapest that I’ve heard is $16K, which was about the only one that has made financial sense to me, and the most expensive was $98K. The standard range is $40-70K around here, which I find ridiculous.
One thing that most people in FL don't think about is when a hurricane comes to town and rips them off your roof. Homeowners insurance will point to improper installation and get with solar companies insurance. And vice versa.
This is an insurance nightmare for the buyer and a bonanza for the insurance company not paying for all the damage and then raise your rates and drop you next year.
Reactions: Zorba and BlueC
If you bought the panels I listed above and jammed them on every square inch of the roof you could jam 40 of them on there at 150 each for a total cost of 6k. Then double that for the rest of the crap needed and add a couple grand for labor and you are at 16k. Any more than that is thievery!
Yep. When I had a solar guy in to talk about it, my first question was about insurance. He asked me who my InsCo was. I said, "For a house this old? Only one it could be." Every Floridian knows who that is - he didn't. "You mean you do not know the InsCo of last resort in Florida?" "Nope". "Then how can you have an intelligent discussion on the subject? There's the door - I strongly suggest you get an education..."
For the non Floridians, the answer is "Citizen's Insurance".
Co-worker had to have his roof re-shingled. When he bought a House that had solar on the roof.
Insurance paid for the re shingle job.
However getting the panels off of the roof and reinstalled was all on him.
I have a solar heating system for my pool. It's extremely simple compared to a photovoltaic system. The pump simply sends water up to the plastic panels on the roof where the water is heated by the sun and returned to the pool. I certainly dont use it during the summer, pool water is warm enough as it is but in the cooler months it's very nice. When I had my roof replacement paid for by homeowners insurance they paid the solar contractor to remove and then replace the panels.
Reactions: Zorba
I have a friend who installed enough solar panels to run his heat pumps for his pool. Now he uses the pool all winter as well.
That is why I don't have insurance...I wouldn't be able to afford mine and yours. :D :D :D
