Somebody get chili_pepper a Snickers.Might just be me but I think the fire light makes your tire look like it's made of red velvet cake...![]()
Somebody get chili_pepper a Snickers.![]()
mjonesjr84, I put the Xpel on my door sills yesterday. I, too, am interested to see how it holds up. I wasn't all that impressed with the adhesive they used. Although it is holding through all those 90° there currently, it didn't seem to have as strong a bond as I would expect to be needed for that application. I fear that time and conditions will not be kind to it. At least it was relatively inexpensive and pretty easy to apply!Added the Xpel to the tub rails. It was pretty easy. We'll see how it holds up when I put the soft top back on this evening.
My door seals are rock solid. I think the adhesive is soft up front so you can move it around. I think that is why the instructions say to install it in the shade on cool body panels. Once it gets the sun/heat on it, the adhesive sits up.mjonesjr84, I put the Xpel on my door sills yesterday. I, too, am interested to see how it holds up. I wasn't all that impressed with the adhesive they used. Although it is holding through all those 90° there currently, it didn't seem to have as strong a bond as I would expect to be needed for that application. I fear that time and conditions will not be kind to it. At least it was relatively inexpensive and pretty easy to apply!
Good to know - thanks!My door seals are rock solid. I think the adhesive is soft up front so you can move it around. I think that is why the instructions say to install it in the shade on cool body panels. Once it gets the sun/heat on it, the adhesive sits up.
Eastwood makes a product (paint) that uses a tube and a 360° spray tip to paint inside the frame,While the frame was open I needle scaled the inside to “smooth” and brush applied Zero Rust
Zero Rust 62SP Black Rust Inhibitive Coating 12oz Aerosol
https://www.amazon.com/dp/B07XF5TW8Y?tag=wranglerorg-20
Problem I have is when welding the sections to the old frame I’m sure the interior paint is being burnt away.
After this is done I’ll probably maintain it with some sort of oil product.
Unfortunately i didn’t photograph the inside when prepped but i will on the passenger side.
This is a fun project but in the end next time I’ll spend more and buy a rust free Jeep
Yes, this stuff... definitely need to do good prep work first but it sounds like he's getting that taken care while the frame is open.@Woodrow was just talking about that in Psri's thread
So far I've been very impressed. It is rock hard on my door sills. Hopefully it holds up as well on my tub rails.I've had Xpel on my door sills for a year without any issues, but I've only put about 2.5 - 3k miles on it in that time. Temperatures in my garage range from 40 - 110 degrees, if that's at all helpful.
Purchased a new upgraded Tom Woods front driveshaft.
Leaving for a 3 week trip to the Philippines this Sunday; so upgrading the driveshaft will need to wait until I return.
I've thought about using their PPF on my Silverado. Good to hear it holds up good.I have the entire front of my Superduty PPF’d with XPEL clear and it’s held up fine.
Young kids who like to scare you from behind? Asshole friends who like to prank? Trying to hide something from the wife/gf?
Come on - you've got to share what's up with the mirror... Who are you afraid is behind you when you're working at the bench?![]()
The vents are to relieve pressure in the cab.Installed Dynamat and Bedrug. Ordered Bartact seat covers in black with gray inserts, front & rear, so let the waiting begin. There is a Bedrug piece that goes over the tailgate but my 2006 has vents. Don't know for sure what purpose those vents are for with soft top. I didn't do it but do you think it is OK to cover?
That vent replaced the vents that early TJs had in the hardtop:There is a Bedrug piece that goes over the tailgate but my 2006 has vents. Don't know for sure what purpose those vents are for with soft top.
yesI didn't do it but do you think it is OK to cover?
