This frame looks about as clean as i have seen for an 04, but I don't thinl i jave seen this "extra" bolted on crossmember. Im assuming it's because I'm a newbie. Any info/insight would be appreciated. Thx in advance!
It's the 4.0 I6Okay, that's bizarre. That extra crossmember almost appears to be factory, and I'm not even sure what it's there for.
Is this a 4 cylinder model or a 6 cylinder?
It's the 4.0 I6
Is that something that should be of concern? From what I can tell from the pics, the frame is pretty clean for a 2004 in Western NYI've never seen that before, ever. I wonder why it's there?
It's definitely not factory to my knowledge. My 2004 didn't come with one, that's for sure.
Isn't that a support for the auto tranny? I know my frame has openings for an additional nutsert there, but since I have the manual, its open.
I assume the crossmember you're talking about is the one ahead of the skidplate...
Your current one was probably already removed, due to it being lifted. Was your first TJ lifted when you bought it? I guess there is front driveshaft interference when you lift them so they are removed pretty commonly (from 5 minutes of google research)
the lift would likely cause the driveshaft to hit the crossmember.
