Yes sir I did! Not too long before I bought my 400$ set, I placed an order through vivid,longstory short the odds were on my side,canceled that i did through vivid racing and saved alot of money
Bear with me here with the pics,I basically just ate like a full 3 course meal before getting under my jeep so pics might be a bit bad
I will admit I am afraid to discover that once I get an engine skid I bet this system may interfere with an engine skid,I wonder if a 1" mml could help?
To note I'm at Essentially stock height and no bump stops
Look at pretty blue color
Anyways here's some more pics.....
Here's my fist for
scale ! My thumb was touching the cat.
At full stuff my drive shaft u joint likes to kiss my pretty header.....hopefully once I install a body&motor mount lift it should help with clearance along with more bump stop once I go taller it'll nit hit,An HP30 with all the listed mods might beg to differ
Anyways i digress...more pics
The ujoint and header kissing action I talked about.....not too bad all things considered,wasn't too happy when I heard and seen that when I was out on a trail
Hopefully this helps if anyone is seeking this setup,I'll see how it clears with an engine skid,if anything an oil pan skid might have to do(the one you directly bolt on the pan),I've already hit that and especially my tranny oil pan, once again I'll see how it all pans out
once im there(hehe....."pans out "
ahhh so funny.....)
Edit- I can most likely push the cat pipe up once I get my 3" exhaust setup,I just pushed it up a bit more since my cat pipe is kinda sorta being hanged with a clothes hanger wire
......(because of the steering thats now been replaced) Death wobble at 90 mph got the better of it and made the hanger break due to the lack of support and the mufflers weight leveraging on that single hanger that no longer exists......
