I’ve scoured all over these forums and the internet and can’t find an answer, so here goes.
Just finished the rebuild on my 2002 4.0 and got it installed and running. Engine runs great, however I’m having a cranking issue. I replaced the batter, spark plugs, and injectors. New cam sensor and OPDA as well. Before first start I set crank to TDC on #1 compression stroke based off the vibe damper, set the cam sensor in the same direction the old was without removing the pin for TDC and then used my Innova 5610 to perform the cam/crank relearn.
I’ve had guys tell me it sounds like a timing issue, but since it’s all PCM controlled I don’t know the process for that.
Could it be the starter is giving out? Far as I know it’s the original with 276k on it.
