Need help diagnosing brake lock up
TJosh02
Toronto
So Saturday, I was the tail gunner on a fun trail for my club in slick greasy conditions. It was a 3 hour drive north to the trail we were doing. The night before I did an oil change, as I was a bit overdue. One thing I noticed was that I only got about 3.5-3.75 L of old oil out despite putting 5L in (I thought that was correct amount), and was a bit overfull. I mention this in case it matters, but plan to drain some out to make it right again.
I drove up to the area where all our trails reside no issues (~3hrs). Completed the trail with no issues (~ 4hrs). Went to do an add on trail, with 2 guys who wanted more like myself, and kept blowing my fuel rail fuse in the box**. There was lots of water on the trail, and I think it is a grounding out some wires. (** edit, found the source. The upper control arm on the mid-arm kit was pinching the fuel power line between itself and the body and was shorting out. Re-routed and repaired the wires (I didn't install the kit, a defunct shop did) so hopefully that solves it. ).
Got back, finished, aired up and when driving out the 10km of forest roads back to the highway, I noticed the power was terrible. It was bogged bad. Then one of my mates behind radioed he smelled something burning and saw smoke. We pulled over. I immediately went smelling and the front calipers were cooking. Up till now the brakes felt normal pressure wise. I turned it off and then the brake pedal was rock hard to push. Put it in neutral (5 spd manual) and the t-case in neutral and couldn't push it on flat ground (parking off as well, not that is is worth a damn anyway). Couldn't figure out why they were locked up, so I called CAA (like AAA but here in Canada).
While I was on the phone to CAA, I let my buddy who I trust investigate. He pulled the master cylinder from the brake booster and heard the pressure let off. They backed the brake booster push rod back some and put it back to use. It drove normally after. The brakes were not locked up, but the brake pedal a bit softer, meaning I had to push it in more. That makes sense since we experimented with the push rod adjustment, but it seemed more to due with letting out the pressure. [ I think he backed it up way too much, less than half would have done it, but we were roadside experimenting ]
But why would this all the sudden be? Why was I getting too much pressure? It is like the vacuum was far too strong in the booster. The master cylinder seemed to function fine, but I have no frame of reference.
Ran up there the 3 hrs no issues. Ran the trail no issues (~ 4hrs). Went to do an add on trail with 2 guys who wanted more like myself and kept blowing my fuel rail fuse in the box. There was lots of water on the trail, and I think it is a grounding out so wires, after I clipped the extraneous spliced wiring my dad has done to the passenger tail light for the trailer hookup I no longer use. (Again, just full details, even if it isn't relevant. I plan to do quite a bit of electrical "clean up" once and for all on some stuff, this happened once before last season so I knew where to look for this).
Occam's Razor- something changed in the booster that caused it to move a slight amount and the booster push rod was adjusted too long to start with.
I get it but I am not satisfied until I know the why. Don't mean you have to tell me but I'd like to discuss the possible causes
Ps, thanks for the response. I consider your word as bond
I have been tied up a bit and hadn't had much time to investigate. However, yesterday and took a good look at my brakes. I jacked the front end up and both wheels sound like metal on metal and my rotors feel pretty rough, especially on the inside side. The outside face has an inch near the top that is pretty rough and gouged in one spot.
I put these brakes on in Jun 2019. Not sure how many miles, probably in the 10k ballpark. However, our trail conditions are a bit rough, lots of muddy water puddles 20+" deep on average throughout the trails. I know that puts some wear on things.
I read on of mrblaine's remarks to someone else. First paragraph here sounds exactly like what happened to me. Surprised that it happened out of the blue.
https://wranglertjforum.com/threads/brakes-are-smoking-and-feel-stuck.10861/post-1403392
Check the pads. You don't normally see that much damage to a rotor unless the friction layer is gone and it really is metal to metal.
I will. I ordered new pads from you (also drums/shoes). Do I need new rotors? Or can they be resurfaced?
