Not sure, just had the jeep a few weeks.
Oil fill cap, guess that's the odd area in valve cover, just behind the inlet air tube?
I guess replacement caps are available?
Is threaded or just pulls out?
Yes, that's it and it's threaded. I used a pair of channel locks when mine did that.
They all do it eventually. I was working in an oil change shop in high school when these things were new and was already seeing them come apart back then.
If you are talking about the heat shield under the fuel rail, here are a few shots of mine. Mine really needs to be replaced, but it's still doing it's job.
Here's a couple of my 06 if any different angles are helpful. I took these deliberately for the heat shield because I had just replaced it after the old one disintegrated while replacing the valve cover gasket.
