I picked up a ’00 5 speed back in February. Now that the heat of summer is on us, I’m in the Houston area so heat and humidity are doing their thing. I’ve noticed I get some excess heat coming from the right side of the transmission tunnel near the parking brake area. After some research I see the majority of its probably from the exhaust/cat, as it sits right there. It does have carpet, however its nothing fancy or “thick.” I’d like to lay some heat insulator on the tunnel and associated areas. I am not concerned with noise at all. I want to block as much heat as possible. With that, I’ve been doing some research, however not sure what to go with. Most of the stuff I’ve found seems to be more for sound deadening and a “heat insulator” second. I don’t care to do the entire pan and would prefer something I can cut to shape. What are some of y’all using to knock the heat down a tad? Thanks.
