Maybe I missed it but I thought your goal was cleaning up the wiring? What’s the deal with the Home Depot nylon butt splices?
Temporary splice to figure out the routing. I'm only halfway done. Keep up.
Because if I don't do it now, it will never be done- a large part of today was spent shortening and cleaning out the ARB locker wiring harness.
Every round gets more wire wrapped up and put away.
Adding the second wire chase through the firewall helped a lot to keep things from getting too messy. One hole is for the SwitchPros and the fuse block where everything routes the same pathway and the other is for everything else that goes the opposite direction.
Halfway done!
Everytime I buy something with an ARB harness 75% of it gets tossed. ARB likes their overly complicated harnesses.
Custom harness is the only way to go.Been looking at lights a lot lately, and the harness that is included with any of the kits seems way overcomplicated and long. That’s the problem with universal. The guy putting reverse lights in a 4 door, long box tow pig gets the same harness as the guy who wants to put them in a TJ or smaller vehicle. And, they charge a ton for them. Baja designs has a flush mount reverse light kit for something like 355 dollars. The individual lights are less than 140 a piece. So, that harness is 75 bucks! Seems silly, especially if you have some sort of switch relay already installed.
My Baja harness made sense to use because it came with the other half of the light connectors. From there, I was also able to reuse the wire to make my own harness.
I have a pair of flush mount trims for the third pair, in hopes that they can be inset into the sliders similar to how Blaine did on a recent build.
The problem is that the spacer block that supports the rocker against the torque box is exactly in that spot. In order to recess the mount, I will need to partly cut into that spacer. Doing so should be fine, structurally. I just need to figure out how to do it cleanly. A router with a circle template might be the solution.
How come a holesaw wouldn’t work?
I wouldn’t think that rock light in the slider would last very long in that spot. Is the housing metal or plastic?
Aluminum. I have mild concerns about that, too. The previous owner of my sliders is from California who used them in JV and who knows where else. There are no rock scars on that surface. Partly, from limited use. But also because that spot is largely shielded by the body mount, frame, the tire and the outer edge of the slider itself.
If that is the set that matched up to the corners, the use was not limited IIRC. Wheeled with him many times in JV and he was one of the first sets of those sliders installed.
The KC flush mount housing is cast or die cast aluminum. How many scratches do you actually have on the bottom side of your rock rails close to the frame right in front of the rear tires?
