Having seen it firsthand mrblaine puts more thought into the packaging than most companies put into the product itself.After unpacking the lights, I realized he is both a Jeep and packing Wizard!
Jack it up and check the unit bearings for play- the least bet can wreck the tracking-
They are brand new Timken, but I did get them from Amazon, so this wouldn't be a bad idea!![]()
16" kitIssue #3 - With heavier 35" tires and wheels, the brakes are not sufficient to stop the Jeep safely. This latter one has me less concerned, because I'll just end up ordering a BBK from Blaine. The only thing I need more information on is what the primary difference is between the 16" and Super 16" kit.
Caster up there ok??
That is plenty if you are getting a good read-I need to get a digital gauge, but measuring from the flat spot on the bottom of the lower ball joint I'm at 5° to 5.5°.
Gearbox ok?
And shaft bearing? We found those finally.
Re #1 How much does the LJ weigh now?
Re #2 If caster and toe and tires (pressure and tread wear) are good, then I think about “memory steer” which is a term I’ve heard referring to poor on center stability due to excessively tight steering components. I had this problem with Carli ball joints on my Dodge pickup. I know its weird because loose ball joints can cause steering issues as well. Either way; ball joints?
I had a front end on my truck done a while back and it came out of the shop too tight- It was one of the scariest things I’ve ever experienced- It was unable to return to Center and “locked” wherever you had the wheel at any time-
It was fixable but not fun. I really didn’t know what was going on at first.
I don't recall all your latest upgrades but if you haven't had a laser alignment after suspension upgrades, I recommend getting it done by the pros. I kept trying to use all the tape measurement methods mentioned on this forum and yet my Jeep was a terror to drive.
My local dealership lifts Jeeps so I took it to them for a laser alignment. —> The Jeep was on rails driving it home. Crazy nimble that I'm still trying to get comfortable with after the terror rides I had after each 'at home' alignment I tried.
Any local shop that modified trucks, Jeeps, etc. should be able to do a good laser alignment. I wouldn't take a modified Jeep to just any shop for alignment - pick one that modifies larger vehicles.
Before you get carried away, do a test on a straight road without much camber. Try to drive it straight with the steering wheel on center. Pay attention to it not wanting to be centered as in as soon as it gets to center, it pops over ever so slightly to either side requiring constant correction because you can't drive it with the steering wheel centered.Issue #2 -The steering seems to easily wander left to right and vice versa. I'm constantly rocking the steering back and fourth to keep it centered in the lane. All the components are new, with the exception of the Ball Joints. I did check those for any movement and didn't see anything abnormal. Alignment wise, I did my own, which I've done multiple times in the past.
