kraft american cheese singles to hold a speaker on my bike (with the help of some aluminum tubing and friction fitting)
Andy
Unfortunately everyone sucking on the pipe resulted in the generation that doesn't know how to tune carbs.![]()
I've been going through carburetor woes on a yj recently. Thinking about either a motorcraft 2100 of even 4.0l injection as a solution
Are vehicle carbs similar to dirt bikes & quads where you dial in the pilot, needle clip, and main jet for their corresponding throttle position fuel adjustments?
If you do, pics WILL be required. And I will be jealous.for reference, the plan is im buying a cj
I found a CJ5 with a 350 and muncie m20 transmission that I like a lot, it's just a simple cj5 with that swap and a simple lift and bikini top. which is really nice.
I shit you not I have a bike and i put a speaker in the basket but it kept flying out when i would hit a bump so i put aluminum tubes in the basket to friction fit it in there and i used american cheese singles on a hot day as putty to put it in there
it's efficacy was questionable but generally speaking what i did worked.
I understand that this is a lot of work and im sure buying a CJ would be easier. However for reasons of my own pride or stupidity or whatever it is, I would rather do this because i have the money (i can come up with more than the originally mentioned $4000 for this project) and i have the time.
You can say something is a bad idea for a lot of reasons, What in particular is a bad idea about doing this kind of work? (an engine & transmission swap, or carb conversion and few complex mods to decomputerize it)
im asking as a genuine question because im curious about this kind of thing, not to be a troll or anything. although i understand that all of this is really unconventional.
also i would say to you:
is it easier to do this kind of conversion? or put coil springs on a CJ?
Those motorcraft carburetors are simple and reliable can you find an adapter for it?
Bbd? Use the body from a late 70's dodge 318, gets rid of the feedback solenoid.
Then look at the joker orange edu conversion
Good luck
I got one of those from summit racing and it ran very rich. No numbers on the jets and a bunch of plastic parts. Junk!
You have to set the metering rods and idle mixture
On the upside if you find yourself feeling a bit peckish on a ride, you've got emergency cheese on hand to slake your hunger...![]()
hell yeah and we all know american cheese is synthetic material from aliens crafted in a lab, which is why it doesn't go bad. I'll have adhesive AND food for the apocalypse.
I wouldn't feed "American" cheese to a rabid dog.
I just had a slice of American Cheese on an egg and Canadian Bacon sandwitch, which I made for my wife and I.
Woof.
Woof.
