That RMS leak opinion question
I have it in my garage and the label confirms it's a conventional.
Yeah, I have one in my garage too and it doesn't really say what it is. Just says high mileage, not conventional or syn blend.
I sent them an email to clarify. I'd like use a conventional High Mileage, not synthetic blend, because my RMS is also seeping.
Reactions: Jerry Bransford
I have 2-mopar RMS and fel pro pan gasket, anaerobic sealer in the pile of parts for my transmission swap. I plan to do the RMS at the same time.
I would love to see what pattern you use on the bearing cap with the sealer.
I hate doing rear main seals almost as much as I hate the smell of burning oil under the Jeep.
A few things:
1) I don’t like this job. There’s no way to confirm it’s right till it’s too late and it’s easy to mess up
2) The Fel-Pro instructions say to add a thin layer of grease to the lips if you won’t be starting the engine soon. I’m doing a swap, so it will be awhile.
3) Then I dipped the seal in gear oil to give some lubrication as I pushed it in. I used the little tool Fel-Pro sends. It worked.
4) I cocked the two gaskets so the upper went in about 70% of the way and I met it with the lower going on the other way. I put a dot of anaerobic gasket maker on each side where the two seals met.
5) I used this pattern, and after I torqued down the bearing caps to 80ft/lb it oozed out a bit around the edges both fore and aft.
I don’t have any confirmation it has sealed yet. Doing the oil pan later.
Another source of High Mileage conventional 10W-30 is Fram. I dunno who makes it for Fram but I'd trust Fram to have selected a good quality for them to have put their name on it. F630 by the quart, or F630-5QT for a 5 quart container. It's in various auto parts stores like Advance Auto.
A few things:
Good luck. Like overhauling an engine you don't know how replacing the RMS turned out until you start the engine.
I ran across STP Conventional HM 10W-30 at my local AutoZone. Decent price, as well.
Anyone have experience with this brand?
IMO, any oil is fine as long as you change it regularly.
I've put 300k + on 2 different vehicles with Walmart oil.
Reactions: LJBean
True, but this is about running HM oil to treat an RMS leak to see if it helps before changing it.
Not every brand is going to have the same additive pack, some will probably slow or stop leaks better than others. For instance Valvoline Maxlife HM has had a great rep for stopping RMS leaks. Not sure I'd go with a small brand HM just to get straight conventional oil over a major brand syn blend HM oil.
Reactions: egclassic
Not every brand is going to have the same additive pack, some will probably slow or stop leaks better than others. For instance Valvoline Maxlife HM has had a great rep for stopping RMS leaks...
I would agree. The Valvoline Maxlife HM has slowed down my RMS leak more than the conventional HM oils I tried before.
im about to tackle this tomorrow. I read a ton and seems whether to offset the seal or not is up in the air. I will definitely be using dino oil
I know. It’s annoying. I read and read. It’s nerve-racking. Just finished yesterday. I lubricated them with gear oil to slide in better. I offset them with a dab of anaerobic gasket maker where they meet. We’ll see. I really hope it’s sealed
I’ll be going by FSM. Hasn’t failed me yet. Well once I thought it did but after I pulled the pan back off and found out the pan gasket rolled right under the bearing cap/rms.
I hope this works out man. Good luck. It is nerve racking. Pain in the butt and the cost of oil now geez.
FYI, this is the Pennzoil delivered today from Amazon. Conventional, not a blend.
This is on a shelf of a local store. Also not a blend.
yea there's 2 different one's. Jerry called them awhile back and you have to watch for the synthetic blend labeling because they look the same. but the one that just says MOTOR OIL is conventional....
