...2005 LJ/4.0
Last week, I installed 2.5" lift coil springs and new shocks. I used the stock trackbar and the differential ended up off-center by less than an inch. The steering was off-center at about 25 degrees to the right. I just installed a JKS adjustable trackbar and centered the differential to within 1/8". After a test drive and allowing the suspension to settle, the steering is now off-center more at about 70 degrees.
Is it normal for the steering to be off after a lift? I know the answer is out there, but I'm having a hard time finding it. Should I move forward with adjusting centering the steering wheel at the drag link?
Thanks,
Mike.
Thanks,
Mike.
