Filled up the gas tank today. I got 10.5mpg with that tank of gas.
Installed the Baja Designs S1 wide cornering LEDs on some cheap Amazon clamps and positioned them on the tire carrier. Wiring them in was super simple since I spent so much time organizing the aux power box.
I also did something I thought I’d never do: install something made by Rough Country. I was tired of using a shovel handle as a hood prop—the stock prop rubs the Mishimoto radiator—so I installed their gas strut hood prop setup. Not happy with how to bends the radiator supports when opened all the way without supporting the hood: they kind of flex. May need to adjust them a bit.
Uh oh....
Went to Summit racing saw a Kc pod light,went to checkout and let's just say the bottle flew over to my passenger seat.....
So qnyways yeah the jeep is now getting nitrous,I'll probably just do a 75-100 wet shot.
Do I need this for my daily Lj? No. But will I use nitrous daily ? No.
Does it need it ? YES....YES IT DO CAUSE ME WANT IT
Once I build my new stroker motor and get a tranny I'll most likely dump a 300 shot until it or the tranny blows......
Edit- Can't afford Jezza's Turbo kit yet so nitrous will do![]()
And WEEᴇᴇᴇᴇᴇᴇᴇᴇᴇᴇᴇᴇᴇᴇᴇᴇᴇᴇ as id say as i hit 60 in about 3-4 business days
am I the only one that heard everything happening in that gif even though it's silent?
It's all fun till you kick the Rods out the side of the block !![]()
WOW that is a clean engine bay!
Maybe he could fix that hood?![]()
I think I found a new TJ Friend to clean my motor.
What relay setup is that?
We are very well alikeam I the only one that heard everything happening in that gif even though it's silent?
Or you over pressure the manifold so your floor plan bolts back out allowing it to fall out as you shift into 17th gear.
