Too heavy for what is needed and it projects the tire further out from the body than is necessary.
I have no experience with this thing, but looks like it is a better fit for 37-40s and not 35” and below
just ordered a morrryde tail gate carrier
Hopefully you also ordered the "Heavy-duty tailgate reinforcement (without hinges) JP5-056" which transfers the weight of the spare tire to the rear rollbar support base.
Order yourself 3 new spare tire bumpers. You'll need to cut them down and extend the stock ones so that they still contact the tire. IIRC, Quadratec has them for about $8 each.
There comes a point where the spare is best left on the trailer.
The Moryde kit comes with spacers.
I disagree. For me personally, I run with the 40 back there and deal with the drawbacks. I’d definitely prefer to run without a spare, and instead rely on a repair kit, but I’ve had a few flats over the years, and every single one was an unrepairable cut sidewall. In a smaller park, wheeling with another rig, I’d leave the spare on the trailer. Out west, I’d rather have it with me, as I never want to be that guy.
That having been said, I’ve often considered what it would actually mean to run without a spare. Are the current large patch kits effective enough to patch a large cut? Since I run beadlocks, it would certainly be possible to gain access to the inside of the tire in the case of a cut.
Whatcha think?
Interesting. Mine didn't.
Whatcha think?
Whatcha think?
Much of that would depend on the extent the physical bulk and the weight of a 40" spare hanging off the back is or isn't a performance hindrance to the wheeling being done.
All I know for certain is where my instincts and sensabilities have evolved in recent years where I have been making a concerted effort to reduce both weight and the physical profile of the Jeep. My concurrent interest of staying at 35s allows me to eventually put the spare in the bed, which happens to have value in giving the shocks some weight to react against. Along with centralizing the vehicle weight to between the axles
With regard to tire cuts and punctures, I carry both plugs and patches. Though, I have not had to use either in the trails. I don't yet have a clear plan on how I might deal with a tire slice in conjunction with the Coyote internal beadlocks.
I did pick up a nail on the street recently that I will be using an internal patch on. So, I will be applying that with a mind towards a possible trail patch without tire levers. We shall see.
Depending on how hard you wheel, outside the tub may just not be an option (much less a swing out carrier). Mine kept digging in the dirt and rocks and bending up my tailgate corners. Granted, my LJ is longer with a worse departure angle.
Has anyone measured the clearance at the lowest point of their spare tire?
It'd be interesting to see some numbers with the varying carriers and tire sizes.
Mine sits just above the bottom of the body. 35" tire with a stock spare tire mount modified to sit an inch higher on the gate. That is going to be the only useful point of reference in a measuring contest with a whole bunch of variables.
The distance from the ground is whatever the same size tire creates along with a 4" spring lift plus a 1.25" body lift.
The tire is also pulled tight against the hinges, meaning it only extends out the width of the tire plus the thickness of the hinges.
When are you countersinking those bolts? I've seen this plate like 3 times now, and it just bothers me every time.
