Fixed the gas tank fill check valve in my ‘06!
I'm getting an evap CEL and having difficulty filling the tank, so I suspect I need to do this as well. Any tips?
Squealed for a bit...I was at a friend's house for the night...it died entirely on pulling into the parking lot for hockey in the morning. And I'd only used the clutch twice in the half hour drive. After the game I Limped it home with no clutch
I’m curious. First computer i used was a Comedore Vic 20 then a 64. After that in the mid 80’s (as an elementary student) i was taking an introduction to DOS at my high school on some early model Apple.
My first 'real' (i.e work) computer was the PDP-9. 64KB of RAM, so memory management was huge. DEC claimed they had a FORTRAN II compiler, but it never worked, so we had to code in Assembler. Yes, it is bad when you dream in Assembler language, but it happens.
There is a line from one of the old Travis McGee books: Travis is walking through the mall and sees 100 kids in the arcade playing video games and then sees one kid in Radio Shack writing code for the TRs-80. He opines that those 100 kids are going to make that one kid a lot of money.
Now that you mention, I too am old; at least according to my grand kids. I also still have my slide rule, which was also used to design the first computers. It always works, never needs charging, and is sort of elegant in the use of logarithmic scales. The calculator in my phone is more powerful and functional than my first five hand held calculators. (And it does dec-hex conversions!)
The hardest is getting it in gear....pretty much just held the stick against first and it's slowwwly rides it until it thunks into gear...from then on you can kinda shift wherever, I normally do at 2500 because it doesn't take long for the synchros and I can't shift without clutch in 5th unless I'm 2500 or underHow’d you manage that? You shift gears at 3k RPM?
It was a productive day! Got my old Yakima ski holders mounted to the GenRight tire carrier (I used square tubing welded to clamps from Ruffstuff) and mounted and wired the new Baja Designs Squadron SAE fog lights. Like them a lot.
I got to play in the snow a little bit today. Also got to try out the savvy cable shifter for the transfer case. Since installing it over a year ago I hadn’t really needed 4x4 so I wasn’t even sure it was adjusted properly lol with a smooth pull it engaged in 4 hi and back to 2 lo. I thought when I installed it everything seemed good but it’s nice to know that it works. I also bought a new battery with top and side posts so I can get my winch installed at some point in the future. The old battery is struggling on cold days but hasn’t let me down yet.
Maybe cranked my battery for the final time.
Well got in my Rubicon last night and about froze my little tushy ! decided this morning I needed to add Heated seats since @AndyG has them ! I found a simple mod to keep my skinny butt warm .
I see you have the correct color TJ also![]()
What were you thinking!!!! You just lost 100hp!
I picked this up on 1/4/24 with it completely stock, other than 31x10.50 tires. Yesterday I picked it up from Wheat's Off-Road from getting the 4" lift, SYE & driveshaft, front steering, and wheels/tires put on. It drives & rides much better than before. Obviously the stock suspension and steering were wore out with 193k on them.
This is my first Wrangler, but not my first experience with them. So far, just doing some updating (ATOTO S8 Ultra double din) and replaced all the door/back glass gaskets to stop some leaks.
Front and rear bumpers were supposed to be here today, but with 2" of snow FedEx thought it was hard to deliver.
