I’ve recently had some issues with my 2004 Jeep wrangler rubicon that I was looking for some help with. Since I purchased the vehicle, I’ve had a very loud whistling sound that I assumed to be a vacuum leak. I replaced the throttle body as that’s where a majority of the smoke came out of when testing and it has gotten better. However recently I’ve had an issue of an intermittent surging idle at startup, and stalling when coming to a stop which doesn’t always happen but happens once in a while. The whistle still happens but not as much as it did before, and only happens at idle rpm’s. If the Jeep dips under idle rpm’s the whistle goes away.
Replaced:
Throttle Body
Downstream O2 sensor 2 after check engine light
Cleaned idle air control valve
I have attached a photo of the motor and a video of said whistle/whine
Surging Idle:
https://streamable.com/954ery
Whine/Whistle:
https://streamable.com/fhmh45
Replaced:
Throttle Body
Surging Idle:
Whine/Whistle:
