RTV on splines of pinion yoke
patdugan
Seattle, WA
Hey!
I drive a 99 Wrangler Sport and was changing the oil in the rear Dana 35 when I decided to replace the pinion seal which had been leaking slightly. Upon removing the yoke, I noticed whoever had previously serviced the differential had coated a pretty large amount of RTV on the splines of the yoke and by extension the input shaft.
The Jeep had been driving fine, and I ended up putting this all back together as-is with a new seal and new pinion nut, but now I'm wondering if I should disassemble and replace the yoke itself. Any thoughts?
Thanks,
Pat
There is actually a rubber gasket you can get for that. The RTV is just a stop gap. I don't know that I've ever seen one leak that didn't have the gasket or RTV on it.. So I wouldn't worry about at this point. And if things are working OK now why take the chance pulling it back apart.
Reactions: patdugan
Hey!
Thanks,
Pat
While more common on tcase versus pinion yokes, it is not a bad thing to put a light film of RTV on the splines but whoever did that went way way too far.
Really I only worry about tcase yokes but I can not stand those rubber washers and only use RTV now.
Every time I ever used one of those gaskets it was destroyed the next time I took the yoke off. Both t-case & diff.
